omnitik as a indoor access point
hi i want to use omnitik as indoor access point. for 50 cell phone user how it is possible ?
Are you asking if it is possible? or how to do it?
Yes, you can use it indoors.
How? Plug it in, connect to it, and configure it.
And have you realised that it is 5GHz only? Do your phones support this frequency? Have you studied the signal obstacle penetration according to the used frequency when you are going to use it indoors?
Don´t forget - Omnitik is only 5Ghz.
All your phones support 5Ghz?
That’s life… Someone is always the first.
