Hi I bought a six pack. 1 omnitik and 5 SXT’s.
I like to config a point to Multipoint connection.
Is ther a manual for it?
I’m brand new with Mikrotik (routeros).
This two link may be useful :
http://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes
http://wiki.mikrotik.com/wiki/Manual:Wireless_AP_Client
Thanks.
I allso found this document
Is this allso ok to config the Omnitik and SXT’s?
I like to bridge 5 buildings to 1 main building
In de mainbuilding is the Omintik in the 5 other buildings are the SXT’s
http://www.wispforum.net/entry.php?5-How-to-Connect-two-Mikrotik-SXT-5D-s-In-Bridge-Mode-Part-I
http://www.wispforum.net/entry.php?6-How-to-Connect-two-Mikrotik-SXT-5D-s-In-Bridge-Mode-Part-II
Or are there other beter options?
Yeah that’s Ok for make a transparent bridge.
ok thanks,
And this is allso good performing?
I can bridge the 5 SXT’s to the Omnitik?
Yes, but check your knowledge with http://wiki.mikrotik.com/wiki/Manual:Wireless_Station_Modes
In there read about Station wds and station-bridge and choose the best for your network ![]()
Using NV2 protocol and HT chains will satisfy you.
I read the documentation (the links you send me.) But my english and network knowledge is not zo well.
What I want is to connect 5 other buildings wirreless to one mainbuilding.
The speed is important. Need a high speed.
The buildings are near 200 meters (so not so far).
I thought of bridging.
I heard WDS is nog good if you have 5 devices because your speed is going down by useing WDS.
Anybody a suggestion for me?
Tell us about your network, how many clients are behind each station? what services do you want to use in this network? Are you sure the bridge is the solution or may be it is better to separate networks and Broadcast domain?
When you use WDS, you will have separate dynamic interface for each client and able to manage the bandwidth and put firewall rules.
I have one omnitik and 5 SXT’s
I have 6 buildings
One main building and 5 client buildings.
I likt to make one transparant network
In each buildint are maximum 5 people.
I realy don’t know how to build this network.
The trafic is Active Directory and Media streaming.
Now I use this document to try to make a bridge
http://www.wispforum.net/entry.php?5-Ho … ode-Part-I
http://www.wispforum.net/entry.php?6-Ho … de-Part-II
But I can only get one client connected.
It I try to connect a second client (SXT) I see in the log
Failed to connect on 1580 not allowd too many clients.
So can you please help me?
Sorry for this.
I think you need to make a new post for this error and the MT support and wireless expert will help you.
Good luck.
Just one thing, try to set omnitik as ap-bridge and the SXTs as station.
post the result please.
If I change this to Station and not station bridge it is working.
Thanks a lot.
Is this the best option for me?
