Omnitik & SXT help
Dears,
Hello I Need Help Please With Omnitik And SXT linking
I Have The Omnitik broadcasting and the SXT connected to the Omnitik
the problem is that Omnitik is restarting from time to time
Omnitik connected to 19V Battery Charger - SXT connected to 24V Adapter
Told Me To Reduce The Tx Power - Card Rates To 20 instead of 30 dbm?
Is This An Electricity issue?
I Need to run Supported Rates A/G And Basic Rates A/G From 6 to 54Mbps With Card Rates 30 dbm
if i reduced the Card Rates Will The Network Slow Down ? will i have the same speed ?
i really need help with this thank you
running R.OS 6.19
Hello, have you updated the bios to?
If you reduce the power indeed the link speed will be lower.
What is more connect on the omnitik?
See you something on the log file what happend?
hello plisken thanks for your reply and no just an SXT connected to the omnitek
i have fixed the electricity issue and the board is not turning off any more running it on 24v
but i have another problem i have a high TX and low RX is it and electricity issue too ? and i cant do a bandwidth test its says Can’t Connect
hope you can help with that
thank you i appreciate your help
