omnitik to SXT The Best there is
Hi Mikrotik, you should be proud. I know of nothing that comes anywhere close to this let alone the price. Fantastic work. Just loving Mikrotik. I stick it up, Point it the right way, 5 min config and it just works solid 24/7
Your signal strength is a bit high. You might want to turn it down a little bit if you can.
