Hi
I was called to a client that have a regular router with a directional antenna pointing to this omnitik where it supposed to repeat the signal and allow users to connect free,
No password are defined (it’s an open WIFI). I needed to reset the Omnitik because the original router burned with a thunderstorm and needed to be replaced and new settings were defined. The previous guy didn’t gave me the settings to configure the Omnitik and that’s why the reset to factory defaults.
But I’m not familiar with Microtik devices.
So, what configurations do I need to do to just scan the WIFI from the router and spread it to the other users without passwords?
I just want to repeat the signal, but can’t find a site survey or a wifi scan to scan the network and connect to it…
Thank You
