hi we have omnitik 5hnd , 5.19 upgraded.
we have 6 clients connecting.
Omnitik running ap bridge
clients - station wds
We are seeing customers disconnecting frequently with below messages. We have added them into access list.
7:00:28 wireless,info D4:CA:6D:3E:91:49@wlan1: disconnected, ok
17:00:28 wireless,debug wlan1: D4:CA:6D:3E:91:49 in local ACL, accept
17:00:28 wireless,info D4:CA:6D:3E:91:49@wlan1: connected, wants WDS
17:03:24 wireless,info 00:0C:42:DD:74:F5@wlan1: disconnected, extensive data loss
17:03:59 wireless,info 00:0C:42:F6:D2:AB@wlan1: disconnected, extensive data loss
17:05:28 wireless,debug wlan1: 00:0C:42:DD:74:F5 attempts to associate
17:05:28 wireless,debug wlan1: 00:0C:42:DD:74:F5 in local ACL, accept
17:05:28 wireless,info 00:0C:42:DD:74:F5@wlan1: connected, wants WDS
17:05:53 wireless,debug wlan1: 00:0C:42:F6:D2:AB attempts to associate
17:05:53 wireless,debug wlan1: 00:0C:42:F6:D2:AB in local ACL, accept
17:05:53 wireless,info 00:0C:42:F6:D2:AB@wlan1: connected, wants WDS
17:05:56 wireless,debug wlan1: 00:0C:42:C1:80:A1 attempts to associate
17:05:56 wireless,info 00:0C:42:C1:80:A1@wlan1: reassociating
17:05:56 wireless,info 00:0C:42:C1:80:A1@wlan1: disconnected, ok
17:05:56 wireless,debug wlan1: 00:0C:42:C1:80:A1 in local ACL, accept
17:05:56 wireless,info 00:0C:42:C1:80:A1@wlan1: connected, wants WDS
17:06:04 wireless,info D4:CA:6D:3E:91:49@wlan1: disconnected, extensive data loss
17:06:05 wireless,debug wlan1: D4:CA:6D:3E:91:49 attempts to associate
17:06:05 wireless,debug wlan1: D4:CA:6D:3E:91:49 in local ACL, accept
17:06:05 wireless,info D4:CA:6D:3E:91:49@wlan1: connected, wants WDS
THe configuration is here'
[admin@AP-BRIDGE] /interface wireless> print advanced
0 R name="wlan1" mtu=1500 mac-address=00:0C:42:CD:CE:D1 arp=enabled disable-running-check=no interface-type=Atheros 11N radio-name="AP-BRIDGE" mode=ap-bridge
ssid="singh8028" area="" frequency-mode=superchannel country=no_country_set antenna-gain=25 frequency=5350 band=5ghz-onlyn channel-width=20mhz scan-list=default
wireless-protocol=unspecified rate-set=default supported-rates-a/g=6Mbps,9Mbps,12Mbps,18Mbps,24Mbps,36Mbps,48Mbps,54Mbps basic-rates-a/g=6Mbps max-station-count=2007
distance=dynamic tx-power-mode=default noise-floor-threshold=default nv2-noise-floor-offset=default periodic-calibration=default periodic-calibration-interval=60
dfs-mode=none wds-mode=dynamic wds-default-bridge=bridge1 wds-default-cost=100 wds-cost-range=50-150 wds-ignore-ssid=no update-stats-interval=disabled
bridge-mode=enabled default-authentication=yes default-forwarding=no default-ap-tx-limit=0 default-client-tx-limit=0 proprietary-extensions=post-2.9.25
wmm-support=disabled hide-ssid=no security-profile=default disconnect-timeout=3s on-fail-retry-time=100ms preamble-mode=both compression=no allow-sharedkey=no
station-bridge-clone-mac=00:00:00:00:00:00 ht-ampdu-priorities=0 ht-guard-interval=any
ht-supported-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7,mcs-8,mcs-9,mcs-10,mcs-11,mcs-12,mcs-13,mcs-14,mcs-15,mcs-16,mcs-17,mcs-18,mcs-19,mcs-20,mcs-21,mcs-
22,mcs-23
ht-basic-mcs=mcs-0,mcs-1,mcs-2,mcs-3,mcs-4,mcs-5,mcs-6,mcs-7 ht-txchains=0,1 ht-rxchains=0,1 ht-amsdu-limit=8192 ht-amsdu-threshold=8192 tdma-period-size=2
nv2-queue-count=2 nv2-qos=default nv2-cell-radius=30 nv2-security=disabled nv2-preshared-key="" hw-retries=7 frame-lifetime=0 adaptive-noise-immunity=none
hw-fragmentation-threshold=disabled hw-protection-mode=none hw-protection-threshold=0 frequency-offset=0 rate-selection=advanced multicast-helper=default
signal strength also from -75 to -85 for all customers.
All station wds
logs sometimes shows failed to authenticate, authentication timeout,,, but then they connect automatically.
