omnitik wireless
I have an Omnitik WAP. It is configured as a AP BRIDGE. It is setup to get his IP from a router. If I want to set a fixed IP, where do I do that ? If I go to DHCP Client, I see the IP info when it is plugged to a router but can’t set it manually. I am new to Mikrotik products.
thanks for the help
you don’t want to use DHCP, but want to set up the IP addresses manually? Disable the DHCP client, and go into the “ip address” menu to add manual adresses.
Ok perfect. Is “network” under IP adresses the subnet ?
Yes, in Linux notation. Where /24 means 255.255.255.0 or ´complete subnet´ etc.
