Strange issue. Just received two new Omnitiks using version 6.18, as I was installing them on an existing network using 5.26, I downgraded the Omnitiks, then downgraded the firmware to match. Now, when I plug them in, they won’t boot up unless I hold the reset button for 1 second while applying power. Using this method they come up fine. However, if I unplug them and plug them back in the power light flashes, but the system doesn’t boot.
Not sure what I should do here. Do I need to upgrade all equipment to 6.19?
