Dear Sir
I have problem with omitik, the problem is all connected clients get out after some time.
1- is this wrong configurations ?
2- or is is attack
3- or it is unable to serve 40 online users?
thank you in advance
Dear Sir
2- or is is attack
Hello, look to the cpu usage to find out ore omnitik is overload.
Hello dear
cpu : 9%
voltage : 23.1
temperature: 42C
but it is kickall station out many times …
what i have to do ?
What is the distance of your long distance clients ? Check when the long distance client starting his service then the problem starts or not ?
MTCNA
If I helped you give me karma please I appreciate this
Dear Sir
I have central Omintik, connected about 20 stations ( SXT, nanostation M5 and ALFA) the stations, The distance (500M-2Km).
every station have 2-5 users.
the problems with all stations all disconnect and reconnect again
please answer me omnitik can serve 50 online users or not?
omnitik can serve 50+ online users. I think there is any wrong configuration on omnitik.
MTCNA
What wireless protocol u use on the omnitik?
What RouterOS version?
Upgrade to latest version
Is youre problem solved?
