Hello, I am configuring a CCR2116 with firewall compatible layer 3 hardware offloading (via fast track rules). I have L3 hardware offloading disabled on the WAN port, but enabled on the switch, on the CPU, and enabled on all other ports including the LAN ports. I am using a bridge, and the LAN port is a member of the bridge. There are also a few VLANs split off the bridge interface.
Is that the right way to set this up? Or should L3 hardware offloading be disabled on the LAN port? Checking and unchecking the L3 offload box on the LAN port does not seem to have any impact.
