One 2.4GHz and one 5GHz antenna on the same mast?
I need to install one 5GHz antenna and one 2.4GHz antenna on the same mast, can I separate them just 30 cms vertically?
PS: Both antennas are pointing the same direction.
Thanks,
They should not interference.
still, it may be better to put radio card some away, course of magnetic field created etc.
I’ve got a 26dBi 5GHz grid almost touching a 24dBi 2.4GHz grid pointing to the same backhaul 25 miles away without issue.
5GHz is my feed, 2.4GHz is just in case I screw something up I can log in and fix it without driving 45 minutes.
