One AP two frequencies are viewed
Guys,
My AP set to channel 1 (2412 MHz) and has established with its clients.
just wondering… If I scan the AP from client, I found my AP’s ssid running on two frequencies. They are 2412 MHz and 2414 MHz with same mac address.
My question is : why 2414 Mhz shown in scanning result? is my AP frequency leak or something else?
pls sharing from you guys
its shifted frequency, if you set scan-list on client to “default” you see only 2412
your probably running with 10Meg or 5Meg channel widths.
Just ignore the ghosts the client will connect to the highest signal.
I am running on channel width 20 MHz.
martini & tgrand, thanks guys
