One button enable/disable
Hello
I need script that will enable/disable caps-man interface. idea is when MODE button is pressed it will run this script. So, same script, need to do enable caps-man (if it was disabled) or to disable it (if it was enabled).So one button can do both.
Now I have 2 scripts
/caps-man interface set [ find name~“House” ] disabled=no
/caps-man interface set [ find name~“House” ] disabled=yes
And Mode button enable it, and reset button disables it
But now I like MODE button to do both enable or disable depending of previus state of caps-man interfaces
Any example ?
/caps-man interface
:local ifdisabled [find where name~"House" and  disabled]
:local ifenabled  [find where name~"House" and !disabled]
enable  $ifdisabled
disable $ifenabled
Toggle interface enabled/disabled, one liner:
/caps-man/interface; :foreach i in=[find where name~"House"] do={ set $i disabled=(![get $i disabled]) }
