one cool idea for winbox
hi guys,
I was thinking if it is cool to winbox to 2 or 3 or N number of boxes at the same time and modifying rules which will be added to all of connected box simultaneously, meaning for example if you want to block a mac address,
you don’t need to winbox to all of them one by one,
simply when you launch your winbox before connecting, selecting a range of boxes in neighbor and modify rules in them.
thanks
you can use a centralized radius server where you manage your users, including the blocked ones.
That was just an example, radius does not order RouterOS
to block a MAC address from connecting to a wireless
access point.
I’m talking about the whole winbox shared options.
for instance like the suggestion you made for the other post if you want to drop all packets except destination port 80 and you have 200 access point in one hotel, you have to do that 200 times, and maybe each one will take 20 second which is 4000 seconds, and that is 1 and half hour.
if feature will be added than IMHO to DUDE not to winbox, since dude has many neat features already
well that is also good, I’m just not used to dude, that’s why I suggested winbox first
using dude you will save a lot of time and phone calls from those who use your network
