I didn’t setup any IPs, I have to make it work on L2.
Both RB750GL were reset to nothing. Not even default config.
Then I just added these:
add interface=eth5 name=vlan-10 vlan-id=10
add interface=eth5 name=vlan-20 vlan-id=20
add name=br-vlan10
add name=br-vlan20
add bridge=br-vlan10 interface=vlan-10
add bridge=br-vlan10 interface=eth1
add bridge=br-vlan20 interface=vlan-20
add bridge=br-vlan20 interface=eth2It does what is supposed to do, I just need now to make eth3 to “see” all VLANs and computers belonging to them.
Nick, can’t do that - or at least it doesn’t allow me to do it, since I have already bridged vlan-10 with br-vlan10 and vlan-20 with br-vlan20 (see config above).
Based on Nick’s concept, I tried this:
/interface vlan
add name=br-multi
/interface bridge filter
add action=drop chain=forward in-interface=eth1 out-interface=eth2
add action=drop chain=forward in-interface=eth2 out-interface=eth1
add bridge=br-multi horizon=1 interface=vlan-10
add bridge=br-multi interface=eth1
add bridge=br-multi horizon=1 interface=vlan-20
add bridge=br-multi horizon=1 interface=eth2
add bridge=br-multi horizon=2 interface=eth3I had to add the bridge filters, since I noticed traffic between eth1<->eth2, which must be avoided.
I played with the “Horizon” values (don’t know what this does exactly ), but never succeeded to make it work as needed.
So, with the config above:
I can “see” everything from eth3 (Great!)
On eth5 I get duplicated the traffic from eth1: one as VLAN10 and a copy as VLAN20.
If I switch Horizon values between eth1 and eth2, I get (on eth5) duplicated the traffic from eth2.
add name=br-multi
add bridge=br-multi horizon=1 interface=eth1
add bridge=br-multi horizon=2 interface=eth5…and I am getting on eth5 traffic from eth1 as VLAN10 and from eth2 as VLAN20. Plus, I can “see” everything from eth3.
Now I have to figure out what to do on the other RB750GL “B”, which receives this mess and must split VLAN10 traffic to it’s eth1, VLAN20 to eth2, and still be able to “see” everything from eth3 of RB750GL “A”…
EDIT:
Correction: Outgoing traffic of eth5 is the sum of eth1 + eth2, but VLAN tagging is missing… (Torch speaking)
Well, I can’t make it work.
I did something which I’m not proud of: Since VLAN tagging was missing on traffic sent by eth5 of the RB750GL “A”, I used Bridge filters (source MAC address based) to separate traffic at the RB750GL “B”. It works, but this is an unorthodox solution.
Perhaps my needs can’t accomplished with RB750GL, don’t know…
