I have an RB2011UASRM, it has 2 x 5 port banks what appear as separate banks.
I have tried to use them as if they are separate, I have configured one as a NAT router with a public IP ..137.242/28 on the WAN and Local subnet on LAN, the first port on the bank is the WAN and the others switched together to form a 4 LAN port switch with DHCP server and local subnet 192.168.88.0/24 192.168.88.1 gateway, 8.8.8.8 as DNS all Straight forward ad it works, srcnat and masquerade set on WAN interface.
So I thought, I will configure the second bank in a similar way except public IP is ..137.243/28 and Local is 192.168.1.0/24 192.168.1.1 gateway, 8.8.8.8 as DNS and I have now changed the srcnat on each interface to include the src address which is either 192.168.88.0/24 or 192.168.1.0/24
It does not work, in fact nothing works, it even stops the working bank from working.
Any ideas?
