one ISP and 2 router CCR-1036
Hello
i have issue with connection on cloud
i have 1 ISP connection and have 2 CCR-1036 Router i need connection from cloud to CCR-1036 number 1
if i put any cloud key in winbox i see only one router i can’t login the other CCR-1036
how i can login Separated cloud?
Isn’t that obvious ?
You should use portforward to access the second router…
You could also enable romon on both routers…
i have global website for my network Connected via api
but i have 2 router i want to control separately ,
I currently only control one router, I cannot control the other router from API
if i put any cloud for router to winbox i login to only same router number 1
look at photo
