I have set up my Mikrotik hAP ax2. I want to have separate 5GHz and 2GHz network. However, when I set it up, the 5GHz one becomes hidden and only the 2 GHz visible. How can I change it, so both are visible?
Are you sure there is no time out because of radar detection ( DFS check) ?
Can take up to 15 minutes.
I doubt that… It definitely was not showing even after those 15 minutes…
hoelvo, I cannot wait for you to ask another 100 hunt and peck questions! ;-PPP
Please post config, so we have a sense of your config…
/export file=anynameyouwish (minus router serial number, any public WANIP information, keys etc.)
