I am looking for the solution for Mikrotik Router where I can use one WAN port for only Up-link and second WAN port for only Down-link Please guide me how it could be configured
I read this link but i did not find any solution from it they want to communicate TCP and using different ISPs. But I am using same ISP and same Speed Internet connection for both WAN ports and I want to communicate the UDP packets on it.
Do you want to change the route of ALL traffic on these two connections or just UDP. If your ISP will cooperate with you and you want to send all your traffic (not just UDP) out one interface all you should have to do is set your default gatway for that interface and have your isp set your routes reachable through the other interface.
I just need to use One WAN as Up-Link and One WAN for down-link I need just simple solution that’s it. Do not confuse me as you know routing is already so confusing.
Thanks and regards
If you are trying to do PCC on two providers and natting the rest of your network this cannot be done
If you are using BGP between your providers then the easiest way to change upload is to set your default route for your upload provider -HOWEVER- you will need the cooperation of your upstream providers to make this work as it is likely your traffic will be dropped if it comes from a network that is not one your provider expects. To change the download you will have to have the upstream providers change their routing advertisements to match what you want.
