I have a script in my RB4011iGS+ (running 6.49.6) that creates backup, export, and version text file every night and then sends those files via E-Mail and also via ftp to my file server. Works perfectly on the 4011 - has for a long time.
I had a need to dig out one of my old RB750r2 (running 6.49. routers for a specific purpose and ported that script to the RB750r2. After changing the file names to be appropriate for the RB750r2, the script creates the three files and sends them via E-Mail just fine, but the ftp fails.
While troubleshooting, I entered a print command to verify that the files were there, and then the /tool fetch command from the script. This works perfectly on the RB4011 (with appropriate filenames), but gets the 550 error message shown below on the RB750r2.
I have a vague recollection that on certain versions of hardware, file locations are specified differently, but for the life of me, I could not find that in the Wiki. What seems odd is that the E-Mail command can find the files, but fetch can’t.
Read better: is FTP server said, not RouterOS said…
Try to set the name identically to what you have already used for the 4011, probably dst-path=“RB4011iGSplus_Version.txt”,
The problem is on your FTP server… the user have the right to write on that user folder, or user folder already exist? Etc.
Nope. Odd wording as it may seem, that error is from RouterOS. To prove that, on the 4011 (where the command works), change the filename to a non-exist name and that is the error message sent from RouterOS. Also note, that the FTP servers never sees the connection attempt at all if the filename is not correct.
I assume that wording is that way because RouterOS is using the same ftp engine for both client and server operation.
Both routers are using the same logon credentials and folder location for the ftp server.
Here’s the same info from the 4011 (where it works perfectly):
Did not have time to do anything until last night, and nothing that I did would make it work. I didn’t see your added / suggestion until just now, so I’ll give that a try next.
Unfortunately, that would be a royal pain in the ass. Router 1 (the RB4011) is my main router so EVERYTHING is routing through it. Changing it's IP would cause a lot of stuff to fail, or a lot of work to change things.
As far as routing, both routers and the file server for my .201 LAN are connected to ports on the same CSS326 switch. On router 2 (the RB750r2), traceroute confirms a single hop to the file server.
I have confirmed that the IP access rules in the FTP server on the file server are allowing the IP for all three routers.
Next step is to fire up WireShark on the server and make damn sure that packets are or are not making it to the ftp server. That will be this evening.
You have been very helpful in many ways over the years - so thank you for trying here. One of these days I (or someone else) will figure this out and the result will get posted here...
It’s working now, and I don’t know why. All three routers working perfectly. The last step (after getting the ftp all working) was to add a .cmd file on the server that added the date on all nine files every night after the ftp uploads completed - easier to that in Windows than ROS…
