one set of antenas rx other set tx
hi all
want to know if you can help me i want to make a connection to main site but need to have one set TX sending the info and a norther set RX any one with simulator set up or info how to do this .
and one more thing i know this is a thing that every one is struggling with is 2 or more gateways to use both of the i want to set the one gateway to browse need ports for that and the other for online gaming need the ports for that two. and if you can help with set up me still new in this router setup can set up one internet connection and share it but two beyond me at this moment .
thanks for you’re time you are much more help full than ones in South Africa
vincent
:confused:
Do you mean nstreme dual?
That is It
will this set up work?
http://www.cyberbajt.com/cyber.php?get=raport,353,90,355
yes, that should do it
