One SSID 3 mini pci
hello
i have router board OS 4.11 Level 5 with 3 mini pci 2.4 Ap
after all normally configuration (how i can show one ssid with mesh or without )
is that really the mesh can show one ssid ? if yes How plz ?
if yes but without mesh how too plz ?
Thank you ?
mmmmm?
You are looking for the WDS functionality, It should be fairly easy to set up using the guide on the wiki, It will display as one AP,If i understand correctly you have 1 Device with 3 cards, and they are on sectors?
Then WDS will be the right way to go, please be aware that WDS is not fully compatible with 802.11N (unless thats fixed), so be aware of that. In this application i don’t think it would be an issue.
hello ,
you can use 3 mini pci exp: XR2 or R52H but use these cards on three sectors but different SSID , coz when the SSID one the customer will connect on one SSID mean on one sector and all load will be on one CARDS , So I would recommend using three different names instead of using one name and will be there Load on a single card and the rest will not be there carrying them, while when there are 3
You are offended variable will be divided among these Rtat pregnancy will be strong and be network The load on everyone …
Any questions I found …
