one to many
hello
i am install a lhg 5 at my office where internet have and i wants to as server and i wants to get internet at my house and alos my another house and 1 more place (total 3 clients)
can i get connection there is it posible.
It is not possible unless you bought separate Level4+ Router OS
LHG is being sold with RouterOS Level3 which is described as “WISP CPE” - it supports wireless client and bridge but not a station (AP) for multiple clients.
So which one I have to buy to make station in 3-5 km area range
How far are these locations from each other? If they are in either 90 or 120 degrees you can use the following:
90 degree
https://mikrotik.com/product/RBSXTG-5HPnD-SAr2
120 degree
https://mikrotik.com/product/RB921GS-5HPacD-15S
sector antenas like this might have troubles reaching up to 5km.
free path loss:
(3 .. 5) km = (116 .. 121) dBm
for SXT SA5 as server/AP with 54MBit rate, in specified distance there will be only: 27 + 16 - (116 .. 121) = - (73 .. 78) dBm
then it depends on client device what kind of antena it has. For example using LHG 5 as client/CPE means additional 24 dBi gain.
RX power will be - (73 .. 78) + 24 = - (49 .. 54) dBm
With this rate, LHG will have -80 dBm sensitivity and link should work. With higher rate, it is not gonna be reliable. If there is interference around, it is also not gonna work very well.
However, if he use CPE with less gain, it is gonna be way harder.
