Dear All.
I started by setting a basic hotspotspot server on a HapLite.
It works like expected.
Next I try to change the IP POOL of default user profile.
The address-to-address list ok, but user can not go anywhere.
I put some of my configuration at https://pastebin.com/YAr7bsyx
Kindly please give me some clue to fix it.
Sincerely
-bino-
Anumrak
2
Hey. And what about your route table?
Dear Sir.
This is the route table :
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
0 ADS dst-address=0.0.0.0/0 gateway=192.168.12.254 gateway-status=192.168.12.254 reachable via ether1 distance=1 scope=30
target-scope=10 vrf-interface=ether1
1 ADC dst-address=10.5.50.0/24 pref-src=10.5.50.1 gateway=wlan1 gateway-status=wlan1 reachable distance=0 scope=10
2 ADC dst-address=10.5.51.1/32 pref-src=10.5.51.1 gateway=wlan1 gateway-status=wlan1 reachable distance=0 scope=10
3 ADC dst-address=192.168.12.0/24 pref-src=192.168.12.3 gateway=ether1 gateway-status=ether1 reachable distance=0 scope=10
4 DC dst-address=192.168.87.1/32 pref-src=192.168.87.1 gateway=ether2 gateway-status=ether2 unreachable distance=255
scope=10
5 ADC dst-address=192.168.88.0/24 pref-src=192.168.88.1 gateway=bridge gateway-status=bridge reachable distance=0 scope=10
Dear All.
It Solved.
I just do ‘System Reset No-Default configuration’ and all works like expected.
I Think something in Hap-Lite’s default configuration blocking it.
Sincerely
-bino-
