i already tired to fix this problem any one can help me for this, how come i got one way audio but i already open the all port and still one way audio
and i’m right that protocol in mikrotik udp is equals rtp? correct me if i’m wrong thank you
if you are using latest version check /ip firewall service-port
there is sip helper there, try changing sup-direct media setting, or try to disable helper altogether.
hello sir janisk thank you for replay topic
yes i see sip 5060,5061 at the service port i try to disable this config if its working hank again sir
thank you for your help sir i try this solution thank you again sir
