Did anyone know if it’s possible to make one way routing ?
I would like to have different route for the upload and the download traffic like the following schema:
of course, why not? setup needed static routes - and voilà! just not really sure about using dynamic routing protocols… and maybe you will want to disable connection tracking on central routers - it won’t work as expectet due to each router will service only one direction of traffic
