one way voice
Hi guys,
I configured my sip device and connect it to my network, it was working fine. Then i take it to internet cafe, connect it to internet cafe’s network. And i checked cafe’s network configuration, and i have seen gateway to reach connection is 192.168.0.3 so i changed it from my device. (gateway was 192.168.0.1 in my network)
That’s the only thing i have changed on device settings. But now i have one way voice problem, i can not hear anything but the other side can hear me.
Than i noticed they are using a Mikrotik RB on their network. I am thinking the problem is because of rb.
What should i check or change in RB to solve this?
I had exactly the same problem. I changed the r52nm with an xr2 and everything was fine.
Check this:
http://forum.mikrotik.com/t/cisco-wip310-g2-r52nm-problem/49642/1
I am thinking if RB has sip filter or something like that is being used as firewall where i can check and turn it off in RouterOS?
