"USB Tethering doesn't work on OnePlus Phones"
is so stupid video on youtube only for money
you are try if on other brand router work?
you know than at the world exist dozen of other competitor routers?
say than "USB Tethering doesn't work on OnePlus Phones" without specify on title or description "only on MikroTik 6.48 that is the only router I haved used"
is so stupid...
and again if "USB Tethering doesn't work on OnePlus Phones"
where are the other users than say the same? you arethe only one than have this problem?
probably the problem is not the MikroTik routerboard but you are unable to use your device
If you are associated with OnePlus in any way it would really help if you can contribute to help address the problem. IMO everyone stands to benefit. If you notice that I am doing something wrong please share the solution and I will, after having verified the suggestion, share an update so that others can benefit. Have a great day
say than “USB Tethering doesn’t work on OnePlus Phones” without specify on title or description [edit]of youtube video[/end edit] “only on MikroTik 6.48 that is the only router I haved used”
is so stupid…
The reason I need this solution is because I travel to Italy a lot and am planning to get illiad or ho-mobile (with their 120Gb per month).
My daily driver is this oneplus and I have a Mikrotik hAP ac lite at hand. Carrying another phone is a complication I would like to avoid (different chargers / sim sizes / inconvenience of multiple phones).
Well I am happy to report that after I updated to the beta firmware and my OnePlus is working.
Thank you to everyone who helped out. I will update the youtube thread accordingly.
