Hello. I have a RB751U.
My Android smartphone got only 54mbps from my home WiFi.
And other phones of my guests too.
In other free wifi zones i see 72mbps in my phone.
How to fix my home wifi?
Thanks.
images size fixed
Thanks.
images size fixed
it is not possible to see the full images of your screenshots. Or at least i cannot.
Your AP is manually set to B/G mode, why did you do that? It will limit the datarate to 54Mbit.
Do a wireless reset, and keep it to defaults. Do not change this setting. In command line you can do “/interface wireless reset” to set wireless config to defaults.
if you set 802.11b what more you expect? Please see wiki.mikrotik.com wireless section on how interface should be configured. Or at least set band=2GHz-b/g/n
you must select 802.11n !!
WTF man. Just set 20/40Mhz B/G/N and rtfm
Anyway I don’t think you will see more than 65mbps on any mobile device.
True.. Most mobile devices only have 1 antenna chain. When using 20MHz channels (default) thats 65mbit.
The chipset of this device can only go up to 65MBit/s
try RB2011UAS-2HnD-IN and you will reach 72MBit/s
or a RB912UAG-2HPnD
