I want to use RouterBOARD to go between a network (192.168.77.0 say) and a specific device (unique MAC) and block any other device from connecting to the network.
What is the best way to set up the RouterBOARD to accomplish this?
Regards,
George
Regards,
George
Try using reply-only. Be sure to add the static entry in /ip arp.
That worked. Thanks ![]()
