So this works fine:
Server - Synology with 10GB NIC
Client - Windows PC with 2.5GB NIC on motherboard
I get up/down 2.5gbps no issues.
Then I put CRS305-1G-4S+IN inbetween with S+RJ10 (Mikrotik Client) and UF-RJ45-10G (Ubiquiti Server).
It shows as active and at 2.5Gbps in windows BUT.
I suddenly get only about 1Gbps (it starts at 200MB/s then drops down to 120MB/s) to the client and around 2Gbps from the client on the S+RJ10. The link is up as 2.5 Gbps though.
The UF-RJ45-10G only supports 10GB so couldn’t try that.
Any ideas what’s up? The synology doesn’t seem to have issues as I can push it hard with multiple clients, just the windows PC with the S+RJ10 has issues.
I haven’t changed anything besides updating to latest firmware on the switch and changing “Advertise” to include 2.5GG Full on all NICs.
I also tried multiple sources at once, not just the Synology and I can’t really get transfer speeds much over 1Gbps.
