I think it’s a bug. In WDS mode p2p if user download in once connection he has from 10 to 30 Mbit. If i change mode to nstream he has 62Mbit/s per 1 connection.
Can it be fixed?
Version 5.10 Ptp with wds mode. Only g 2,4 Ghz 40 Mhz
Per 10 connection in tcp we reached 85Mbit/s.
Thx for help
please provide more info on your setup. What hardware are you using for this setup? what utility you use for testing the speed?
I use routerboard 433AH + Chipset 5213. Link p2p with WDS.
Testing with downbload from ftp or from bandwith test
make multiple support output files when you do those test:
- when you use Nv2 and send one connection
- when you use Nv2 and send 10 connection
- when you use Nstreme and send one connection
Send those files to support@mikrotik.com
The test is done from the windows PC that is connected to your RB433AH board? and the bandwidth test is also made from the windows?
//I think it’s a bug. In WDS mode p2p if user download in once connection he has from 10 to 30 Mbit. If i change mode to nstream he has 62Mbit/s per 1 connection.//
it’s not a bug its normal for nv2
for p2p just use nstream
nv2 is for p2mp test it with 5 or 10 clients than u will see the benefit of nv2
I’ll send to support in few day, i can’t experement with working link.
I also have benedit in p2p link. I have 85 mbit but in nstream 70. Realy 15Mbit/s and it’s better work’s with noise.
If in nstream in some frequency i had 50Mb-60Mbit/s in Nv2 i always had 80-85.
Nv2 is also good for point-to-point installations. Will wait for the support output files.
Hi, I know the answer from support? Basically, all connections with NV2 behave worse than the Nstreme, if used only a single connection. It’s bad, because all clients use the speed tests that use a 1 connection.
THX
Please write to support@mikrotik.com we will provide you with a test release of v5.9 which has lot of improvements using Nv2.
There are news about this topic? I have the same problem with nv2 connections.
