Only Getting 6Mbps on 5Ghz
i have two radios on mikrotik routerbord 200, with minipici but ic ant seem to get it to do more than 6Mbps half duplex. Can someone please help, i need to do at least 10Mbps or better still 20Mbps. Antenna is 30Dbi and distance is 2Km.
amsco
Signal levels?
Exact Freq you are using?
Nstreme enabled or not?
WEP enabled (that slows it down)?
WDS or routed connection?
Regards
Hi Stepen, Signal level is good -58, 5.2Ghz frequency, i have tried both nstreme enabled and disabled but still the same, and it is an EoIP tunnel giving a complete bridge. Hope this helps?
eoip slows it down a lot. try WDS instead (in the manual, look in the how to section)
hi Normus, can i add the lan interface to the bridge to create just one network?
thanks amsco
thanks normis, WDS plus bridging the LAN interface gave me a beautiful bridge and the thoroughput is good.
amsco
How much throughput you can get with wds & bridging ? I have the same problem using eoip.
