Only selected VLANs in WDS sector
Hello
I have some APs set up as AP Bridge, and using WDS.
In on the ethernet interface I have a trunk with several VLANs.
I only want 2 of these (15 and 16) to be sent out in the WDS.
Bot I want to keep the tags, untaging vil happend at the CPE.
How would I do this?
Given that I understand you correctly, you can use a bridge filter rule to exclude all VLANs but the one(s) you want to permit.
Takk skal du ha Vegard :sunglasses:
Thank you Vegard
That works.
I set a filter on the wds-bridge to allow forward with packets tagged with the 2 VLAN IDs, and drop all other.
But how would one solve this.
In on eth I got a trunk.
WLAN1 is a sector witch should have only VLAN 15 and 16.
WLAN2 is a P2P link witch should only have VLAN 10.
WLAN3 is a P2P link witch should have the entire trunk.
Any ideas on this?
