Last night, rather late, after I told my teenager to go get some sleep I wanted to make sure he didn’t lay in bed until 3am playing on his phone so I logged into the router and set the interface 0 (gateway) to disabled status without thinking.
It’s also my DHCP server so now I can’t route traffic through the network unless the devices are using my wireless router set to bridge mode.
Anyway, I have my desktop hard wired to interface 1 (or 2 I can’t remember) and this morning I tried to connect using the windows desktop client and remember that it’s probably not even getting an IP any longer. So I’m wondering if I can pick someone’s brain on how to get that interface 0 back up without doing a factory reset on the router. I have quite a few port forwarding rules setup. While I could probably put them all back in again I’d like to save my config if possible.
That’s the windows client I was using. But it won’t connect. I don’t know if it’s because I don’t have an IP or if you are saying that connecting via MAC address means I won’t even need to configure an IP. Winbox always finds my router automatically but since I disabled that interface it’s not able to connect. I appreciate the suggestions, any other ideas to try next after that?
You can try to connect the cable to any other available ports.(that it if the router has more than one)
or you can connect with one of the devices that usually connects to your wireless.
But you will need to configure static ip address, then try winbox again.
or if you can remember the wlan address you can type it into the browser and navigate to interfaces and enable the device again.
and next time when making changes, always use safe mode! In this case, home router, no big problem. Imagine if you did this to yourself on a router across the country powering thousands fo people!!
