Oops
I installed 5.0beta6 and am getting continuous oops issues requiring pulling the power supply to get running again. Unfortunately I can’t do a /system package downgrade after ftping the 4.11 packages as that also provokes an oops.
System is an RB433UAH with an R52
Typically I get something like this:
Oops[#1]:
Cpu 0
$ 0 : 00000000 7fa8cf80 0000786d d15d0000
$ 4 : 00000000 00000100 00000101 c7672e74
$ 8 : 0000000a 0800ff01 00000000 00000000
$12 : 7fa8cf7c 0000000e 08fe000c 00000064
$16 : 00000001 ffffffff 7fa8cf7c c771a000
$20 : 7fa8cfac 00000000 004cf9b8 004f0000
$24 : 00000000 c02c0070
$28 : c7fdc000 c7fddce0 00fe0001 c7672a58
Hi : 05497800
Lo : 00000008
epc : 8565ab74 0x8565ab74
Tainted: P
ra : c7672a58 0xc7672a58
Status: 1000fe03 KERNEL EXL IE
Cause : 00000010
BadVA : 8565ab74
PrId : 0001800a (MIPS 24Kc)
Process net (pid: 229, threadinfo=c7fdc000, task=c7418478, tls=00000000)
Stack : 00000019 00000000 c7fddc60 c019aa70 c771a2e4 c0259884 c78ae430 c54b9500
00000019 00000000 c771a2e0 c7672eac 00100100 00200200 c74fe310 c0259884
c7fdddc0 c771a000 ffffffff 7fa8cf7c 7fa8cf8c c02777c8 2aaf2a98 004ebb34
7fa8cfe0 c025ffc0 0000000a 00000000 7fa8cf7c c7fdde08 c03c8610 c0278434
0000000a 00000140 c785e2c0 3137322e 0000000a c7fddd78 c7418478 00000001
Call Trace:
[] pollwake+0x0/0x5c
[] mii_link_ok+0x38/0x4c
[] 0xc7672eac
[] ethtool_get_value+0x20/0x60
[] sock_aio_write+0x110/0x128
[] dev_ethtool+0x488/0x1944
[] ktime_get+0x134/0x168
[] task_tick_fair+0x2c/0x124
[] dev_ioctl+0x58c/0x758
[] hrtimer_interrupt+0x1ec/0x3c0
[] sock_ioctl+0x278/0x2bc
[] vfs_ioctl+0x30/0x74
[] run_timer_softirq+0x154/0x1d4
[] do_vfs_ioctl+0x598/0x5dc
[] sys_ioctl+0x48/0x80
[] stack_done+0x20/0x3c
[] sys_times+0x0/0x6c
Code:
unaligned data access at c0109838t
$ 0 : 00000000 7fa8cf80 c7fdc000 8565ab68
Any ideas?
Kernel oops is a case for support. Email support@mikrotik.com.
Done. Thanks.
Looking at the support link on the site, it seems I’m not eligible for support as I bought my routerboard from wifi-stock.com, not from mikrotik directly.
There harwdware / software, they are going to want to know what is up…
Drop support a message…
Ok, got a reply from support to do a netinstall of 4.11. Am stable again and going to leave the beta alone for a while.
Bit of a pain rolling back, as the export scripts from 5 aren’t all compatible with 4. It would be nice if the export script didn’t contain options that are the default. So if option foo is added to an interface and has default value bar, then foo=x is exported only if x != bar.
