OP Limited in 7.1 Configured Router to Only Run 3 WG Interfaces - Please Help!
I can only create 3 wireguard interfaces in an RB4011. When trying to create the fourth one, I’ve got an error in logs saying Could not create IPv4 socket
Anyone tested this so far? Is a bug or just a limitation?
Thanks!
I stopped creating interfaces at 10 on mAP…
Might be config related ?
Please export config and post contents of the file here in between Code quotes.
Problem found! I was creating the interface with the same port as other one already created, reason why ir reports socket error… obviously.
Ok, glad you found it yourself.
You will not forget that one :slight_smile:
Please change title of thread.
OP Limited in 7.1 Configured Router to Only Run 3 WG Interfaces - Please Help!!
Added SOLVED to your suggested title.
Sweet, knew what you meant was just having fun, slow day!! Glad you have good sense of humour.
