if i open 100 tabs chrome at same time my mikrotik CPU is 100 %, any solution for this?
hello no asnwer at all?
What Mikrotik device are you using?
Hap Ac lite sir
The hAp ac lite has a slightly wimpy CPU, so having 100 tabs will easily bog it down. If you use a lot of internet-heavy sites then you might want to get a better router.
so even i disable all firewall rules (mangle, firewall filter, raw) its still get 100 cpu ?
how about buying hap ac 3 ?
Go into Firewall → Connections when you have a bunch of tabs (like 50) and see how many it lists. Also check if you have any firewall rules that have to do with “fast path” or “fast track” because that’s the key to unlocking better CPU usage in routers.
when i open 19 tabs (there are 10 udp connections and 9 tcp connections), it makes 78 list conncentions. cpu 100 %, so what should i do?
Close tabs one by one and check which one causes CPU hogging.
BTW … use “Post reply” button instead of “quote” … se link in my footer.
closing tab one by one is not good way i think, because CPU hogging only for 2 second when i open all 19 tabs.
well, i use post reply for next thanks for the advice
this happen too, when someone on my clinet download using internet downloa dmanager the cpu is 100%
hAP ac lite is a weak device. I’d personally do a clean netinstall of the latest stable RouterOS and set up from scratch again with optimised firewall rules/hardware offloading/optimisation configurations.
Darnate, my hap ac lite is using 6.48 OS now. my bridge-wan is hardware offload (HW) now, but my bridge-lan (bridge wlan1, wlan2 and ether2) cant be HW. do dou have sugestion ?
I stop rstp, vlan filtering, igmp, and mstp but its still cant be HW. please help
Best solution: get a router that can handle your traffic.
hAP ac lite has a not so powerful CPU.
Any reason why you’re using two bridges anyway?
Stick to one bridge.
And stop creating topics all over the place for the same issue.
