When i entre IP address in N82 to open Mikrotik login page then this error occured " No webpage found"
Please provide solution to open login page in N82
Please provide a photo of the issue (screenshot). I would need to see the address bar, and the error message, so see why this happened
I need to access my Mikrotik server Pc on my Nokia Cell Phone N82.
when i write IP in web browser ( 11.11.0.1) following message displayed.
" Error No webpage found"
Please provide solution asap.
Please provide answers to all the following questions:
- is the Nokia connected to the device over wireless (WiFi)?
- Is 11.11.0.1 the IP address of the Wifi interface (the same where Nokia connected)?
- Type “/export compact” in the router command line, and paste the output here
yes, frens
as fas as remember android and nokia can’t open login page, and i am sure you are running on dhcp-hotspot, please make sure your client dhcp network broadcast should be correct value. but don’t know why bb or iphone without problem, hehehe
regards,
Hasbullah.com
android also has no problem with hotspot login
yes, normis
seven months ago i have confuse why nokia or android can’t connect to my roamming.. :
so until now all my client with any device working fine, since i find solution by myself
