Open SSL Wireless
I try to install SSL certificate on the router and I when I connect the wireless I get that the SSL is not trusted, I like to know if you have some manual, and if i need to create a real SSL certificate ?
I need this to create login with Facebook or other social network, if you have some manual for that too it will be great.
Thanks,
Itay Nagar.
