Open VPN Clarification
How many VPN clients can connect to hEX simultaneously, bandwidth not being a factor?
Situation: Currently Asus router is being used with Open VPN and 10 edge users with laptops connect. We are implementing advanced firewall with hEX and wondering if hEX can match this either by Open VPN or its builtin VPN. If this does not work then do you suggest connecting the Asus VPN router behind hEX?
It will hold those 10 users. Just make sure it has good bandwidth. later you just keep an i eye on resource.
hEX has a Level 4 license.
If you look here:
https://wiki.mikrotik.com/wiki/Manual:License
You will see that it support up to 200 VPN tunnels.
