OPEN VPN Client and 7.0BETA 5 / no bride at ISP modem
Hello all,
I will try to explain what kind of problem I have.
I want to use OPENVPN client on my RB3011UIAS Mk router, since I could not use tcp for OPENVPN profile (didnt work at all), so I installed v7.BETA5 where udp is supported, succesfully imported ovpn file and all certificates, and FINALLY openvpn works, but the problem is that my ISP modem is connected to eth1 - and modem does not allows me to use bridge mode (they patched latest firmware and bridge mode is removed)
i used as guide this tutorial, but I have problem with step 5 since i have ISP modem (not in bridge mode) before all
https://support.safervpn.com/hc/en-us/articles/360035919413-Setup-OpenVPN-manually-on-Mikrotik-Router
anyone have idea how i can overcome this issue? or only option is to ask ISP to allow me bridge mode , and then it would work i guess..
