16:54:45 ovpn,info rhbrq: initializing…
16:54:45 ovpn,info rhbrq: connecting…
16:55:05 ovpn,info rhbrq: terminating… - could not connect
No info as to what could be the reason why the connection fails…
I managed to get the opvn working from my laptop (with fedora), so the server works, and I have the correct credentials etc…
There is a NAT router (my internet egress router) between the mikrotik and the internet. But that should not be a problem.
So how do I proceed here? How do I find out more about what is keeping this from working?
(Edit turned out that I had a firewall problem as well. Fixed that now the error is:)
17:26:38 ovpn,info rhbrq: connecting…
17:26:38 ovpn,info rhbrq: terminating… - TLS failed
17:26:38 ovpn,info rhbrq: disconnected
if i read your question correctly you are not using client certificates but added the ca used to sign your server cert as client cert. that probably is the issue. try to remove the client cert param from you client config.
there seems to be a serious problem with openvpn client on mikrotik - the client connects to the server without checking the server cert at all…
i was about to open a post for that already… maybe someone from mikrotik could give a statement about that?
