OPEN VPN routing
Hi guys,
I made routed OpenVPN site-to-site between site A (server side 192.168.1.0/24, router IP 192.168.1.1, VPN IP 10.0.0.1) and site B (client side 192.168.2.0/24, router IP 192.168.2.1, with VPN IP 10.0.0.2). Site A is reachable from site B and vice versa. Also all computers are pingable.
If I ping from site A (lets say from 192.168.1.2) to site B (lets say to 192.168.2.5) and I am monitoring on router on site B with TORCH function all icmp packets on bridge1 interface, I see that icmp packets are comming from 10.0.0.1.
Is it possible to make some routing or something so I will be able to see on site B exactly from which IP those icmp packets are comming (I would like to see that packets are coming from 192.168.1.2 instead of 10.0.0.1).
Yes, by setting NAT rules properly. Most likely right now you are masquerading everything.
Yes, i tried with masquerading all. What should be the proper nat rule?
You need to nat only traffic that you need to nat. Do not set rules to masquerade everything.
