Hi there!
I have a dual WAN setup with PCC & NTH. I wanted to add Open VPN Server & have completed configuration for the same.
OpenVPN client is not able to connect. I can see that packets are flowing till the dst-nat rule but going nowhere from there or somewhere that I am not able to understand ![]()
I am sharing my config here:
# feb/16/2022 17:43:11 by RouterOS 6.49.2
# software id = M149-EZZ8
# model = RB4011iGS+
# serial number = F0380F91C2B8
add admin-mac=DC:2C:6E:32:27:9D auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] advertise=1000M-half,1000M-full comment=\
"Primary ISP" name=WAN1
set [ find default-name=ether2 ] comment="Secondary ISP" name=WAN2
set [ find default-name=ether9 ] advertise=1000M-full
/interface pppoe-client
add disabled=no interface=WAN1 name=WAN1_PPPOEOUT password=password \
use-peer-dns=yes user=username
add disabled=no interface=WAN2 name=WAN2_PPPOEOUT password=password \
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=172.16.1.10-172.16.1.254
add name=open_vpn_pool ranges=172.17.1.2-172.17.1.250
add address-pool=default-dhcp disabled=no interface=bridge name=defconf
/ppp profile
add local-address=172.17.1.1 name=open_vpn remote-address=open_vpn_pool
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add interface=WAN1_PPPOEOUT list=WAN
add interface=WAN2_PPPOEOUT list=WAN
/interface ovpn-server server
set auth=sha1 certificate=Server cipher=aes256 default-profile=open_vpn \
enabled=yes require-client-certificate=yes
add address=172.16.1.1/24 comment=defconf interface=bridge network=172.16.1.0
/ip dhcp-client
add comment=defconf disabled=no interface=WAN1
/ip dhcp-server lease
add address=172.16.1.2 mac-address=E0:63:DA:5C:5B:75 use-src-mac=yes
add address=172.16.1.0/24 comment=defconf gateway=172.16.1.1
set allow-remote-requests=yes servers=1.0.0.2
/ip dns static
/ip firewall address-list
add address=172.16.1.0/24 list=not_in_internet
add address=192.168.2.0/24 list=not_in_internet
established,related,untracked
invalid
add action=accept chain=input comment="Allow OpenVPN Connection" dst-port=\
1194 protocol=tcp
add action=accept chain=input comment="Allow Input by OVPN Clients" \
in-interface=all-ppp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting comment="WAN1 Connection Markimg" \
connection-mark=no-mark in-interface=WAN1_PPPOEOUT new-connection-mark=\
WAN1_CONN passthrough=no
add action=mark-connection chain=prerouting comment="WAN2 Connection Markimg" \
connection-mark=no-mark in-interface=WAN2_PPPOEOUT new-connection-mark=\
WAN2_CONN passthrough=no
add action=mark-connection chain=prerouting comment=\
"PCC Rule for WAN1 HTTP, HTTPS traffic" connection-mark=no-mark \
dst-address-list=!not_in_internet dst-address-type=!local dst-port=80,443 \
in-interface=bridge new-connection-mark=WAN1_CONN passthrough=yes \
per-connection-classifier=both-addresses-and-ports:2/0 protocol=tcp
"PCC Rule for WAN1 HTTP3 QUIC traffic" connection-mark=no-mark \
per-connection-classifier=both-addresses-and-ports:2/0 protocol=udp
add action=mark-connection chain=prerouting comment="NTH Rule for WAN1" \
connection-mark=no-mark dst-address-list=!not_in_internet \
dst-address-type=!local in-interface=bridge new-connection-mark=WAN1_CONN \
nth=2,1 passthrough=yes
"PCC Rule for WAN2 HTTP, HTTPS traffic" connection-mark=no-mark \
in-interface=bridge new-connection-mark=WAN2_CONN passthrough=yes \
per-connection-classifier=both-addresses-and-ports:2/1 protocol=tcp
"PCC Rule for WAN2 HTTP3 QUIC traffic" connection-mark=no-mark \
add action=mark-connection chain=prerouting comment="NTH Rule for WAN2" \
dst-address-type=!local in-interface=bridge new-connection-mark=WAN2_CONN \
nth=2,2 passthrough=yes
add action=mark-routing chain=prerouting comment="LAN Routing for WAN1" \
connection-mark=WAN1_CONN in-interface=bridge new-routing-mark=TO_WAN1 \
passthrough=no
add action=mark-routing chain=prerouting comment="LAN Routing for WAN2" \
connection-mark=WAN2_CONN in-interface=bridge new-routing-mark=TO_WAN2 \
passthrough=no
add action=mark-routing chain=output comment=\
"Routing for Incoming traffic from WAN1" connection-mark=WAN1_CONN \
new-routing-mark=TO_WAN1 out-interface=WAN1_PPPOEOUT passthrough=no
"Routing for Incoming traffic from WAN2" connection-mark=WAN2_CONN \
new-routing-mark=TO_WAN2 out-interface=WAN2_PPPOEOUT passthrough=no
add action=masquerade chain=srcnat comment="WAN1 Masquerade" out-interface=\
WAN1_PPPOEOUT src-address=172.16.1.0/24
add action=masquerade chain=srcnat comment="WAN2 Masquerade" out-interface=\
WAN2_PPPOEOUT src-address=172.16.1.0/24
add action=dst-nat chain=dstnat comment=\
"TCP 80,443 Syncthing(22000) RDP(25000) WAN1" dst-port=80,443,22000,25000 \
in-interface=WAN1_PPPOEOUT log-prefix="TCP FWD" protocol=tcp \
to-addresses=172.16.1.2
"TCP 80,443 Syncthing(22000) RDP(25000) WAN2" dst-port=80,443,22000,25000 \
in-interface=WAN2_PPPOEOUT log-prefix="TCP FWD" protocol=tcp \
add action=dst-nat chain=dstnat comment="UDP L2TP IPSEC(500,1701,4500) WAN1" \
dst-port=500,1701,4500,25000 in-interface=WAN1_PPPOEOUT log-prefix=\
"UDP FWD WAN1" protocol=udp to-addresses=172.16.1.2
add action=dst-nat chain=dstnat comment="UDP L2TP IPSEC(500,1701,4500) WAN2" \
dst-port=500,1701,4500,25000 in-interface=WAN2_PPPOEOUT log-prefix=\
"UDP FWD WAN2" protocol=udp to-addresses=172.16.1.2
add action=dst-nat chain=dstnat comment="OpenVPN Server" dst-port=1194 \
in-interface=WAN2_PPPOEOUT log=yes log-prefix=OPEN_VPN protocol=tcp \
to-addresses=172.17.1.1
add action=masquerade chain=srcnat comment="Open VPN Masquerade" \
out-interface=WAN2_PPPOEOUT src-address=172.17.1.0/24
add check-gateway=ping comment="Load Balance to ISP1" distance=1 gateway=\
WAN1_PPPOEOUT routing-mark=TO_WAN1
add check-gateway=ping comment="Load Balance to ISP2" distance=1 gateway=\
WAN2_PPPOEOUT routing-mark=TO_WAN2
/ppp secret
add name=username password=userpassword profile=open_vpn service=ovpn
/system clock
set time-zone-name=Asia/Kolkata
/tool mac-server
/tool mac-server mac-winbox
Also sharing OPEN VPN client log:
# OPENVPN Log begins
2022-02-16 17:45:09 1
2022-02-16 17:45:09 ----- OpenVPN Start -----
OpenVPN core 3.git::58b92569 ios arm64 64-bit
2022-02-16 17:45:09 OpenVPN core 3.git::58b92569 ios arm64 64-bit
2022-02-16 17:45:09 Frame=512/2048/512 mssfix-ctrl=1250
2022-02-16 17:45:09 UNUSED OPTIONS
4 [resolv-retry] [infinite]
5 [nobind]
6 [persist-key]
7 [persist-tun]
13 [verb] [3]
2022-02-16 17:45:09 EVENT: RESOLVE
2022-02-16 17:45:09 Contacting [x.x.x.x]:1194/TCP via TCPv4
2022-02-16 17:45:09 EVENT: WAIT
2022-02-16 17:45:20 Server poll timeout, trying next remote entry...
2022-02-16 17:45:20 EVENT: RECONNECTING
2022-02-16 17:45:20 EVENT: RESOLVE
2022-02-16 17:45:20 Contacting [x.x.x.x]:1194/TCP via TCPv4
2022-02-16 17:45:20 EVENT: WAIT
2022-02-16 17:45:31 Server poll timeout, trying next remote entry...
2022-02-16 17:45:31 EVENT: RECONNECTING
2022-02-16 17:45:31 EVENT: RESOLVE
2022-02-16 17:45:31 Contacting [x.x.x.x]:1194/TCP via TCPv4
2022-02-16 17:45:31 EVENT: WAIT
2022-02-16 17:45:42 EVENT: CONNECTION_TIMEOUT [ERR]
2022-02-16 17:45:42 Raw stats on disconnect:
CONNECTION_TIMEOUT : 1
N_RECONNECT : 2
2022-02-16 17:45:42 Performance stats on disconnect:
CPU usage (microseconds): 38178
Network bytes per CPU second: 0
Tunnel bytes per CPU second: 0
2022-02-16 17:45:42 EVENT: DISCONNECTED
N_RECONNECT : 2
CPU usage (microseconds): 48199
2022-02-16 17:48:07 RESUME TEST: Internet:ReachableViaWWAN/WR t------
2022-02-16 17:48:07 STANDARD RESUME
# OPENVPN Log ends
Can someone please help me out with this?
Thanks in advance.
Cheers.
