hi,
can anyone please advise if the RouterOS Level 4 router with 4 ports (MikroTik RB941-2nD-TC/UK)
can be set up with Open VPN so that I can install a VPN of my own choice?
thanks
yes, rb941 can be ovpn-client or ovpn-server
more detailed information, you can visit this link
https://wiki.mikrotik.com/wiki/OpenVPN
Just a short info - mikrotik supports OpenVPN only via TCP. not UDP. That has slight impact on performance.
thank you
Yes, it can. There are some limitations:
- Its CPU is quite weak. Don’t expect much more than 20 Mbps of OpenVpn throughput.
- OpenVpn isn’t hardware accelerated. Don’t expect speeds like IPSec, that is hardware accelerated on some routers.
- Mikrotik’s OpenVpn implementation lacks UDP transport, compression and native IPv6 support.
