Hello everybody, i have a program,it called Port Scanner, and when i scan my router, few ports are opened, i have disabled ports in ip services but they are opened some else ports, i will tell the photo, and somebody can tell me how can i block these ports, or close them..Bye
you can configure firewall filter.
First allow the required port and DROP rest of the port.
Just as Ashish says - make one firewall rule that allows access to router from YOUR IP (rule should be in input chain). Then make a rule that drops everyting else
many of those ports are not used by routeros by default. are you using upnp? what does your NAT chain look like ?
Sam
i have firewall rules to,but i just wanna know is it anything danger about my router because i have firewall rules, rest accept and rest drop..
well if your firewall is confgured properly, and in the input chain you “really” have drop rule, then your port scanner is lying ![]()
i really think that he is lying because i tryed to scan another router, with ISA Server, and he found the same port, and i think he is lying..THankYou VeryMuch
for TCP, just simply type in command line ‘telnet <router’s_ip> ’ - and you will see, whether it successfully connects =)
i tryed , and connection refused , i tryed in 22 port, 23, 80 and the same for all..
so… forget this scanner - it doesn’t work =)
