I’m using openfiber connection (italian 1gb/300mbit ftth). Internet provider provided an external ONT and a zte router that I have replaced with the ac2.
So the connection is:
fiber → ont → (ethernet) ac2
I’m not able to reach the same speed connection (680/280 mbit) that I had with the provider router (zte, 910/280 mbit), maybe I’ve made some mistake in configuration.
I’m facing also some issues:
- fing desktop tells that some devices are not able to join my network, but the only device that I’m aware of having this issue is a smart scale
- i’m not able to update the ac2 firmware, could not resolve DNS name, but other devices wired/wireless work well
- sometimes my mi9 se mobile phone loses the IP if connected using wifi 5ghz, with 2.4ghz this issue is not present
Here the configuration:
# jun/26/2022 20:31:11 by RouterOS 6.49.6
# software id = ZNKV-4BZ0
# model = RBD52G-5HacD2HnD
# serial number = 8FDE09971078
add name=bridge1
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
use-peer-dns=yes user=openfiber
/interface wireless
set [ find default-name=wlan1 ] country=italy disabled=no frequency=auto mode=\
ap-bridge name=wlan2.4 ssid=Tiscalli wps-mode=disabled
set [ find default-name=wlan2 ] disabled=no frequency=auto mode=ap-bridge name=\
wlan5G ssid="Tiscalli 5G" wps-mode=disabled
add name=WAN
add name=LAN
set [ find default=yes ] authentication-types=wpa2-psk eap-methods="" mode=\
dynamic-keys supplicant-identity=MikroTik
add name=dhcp ranges=192.168.1.3-192.168.1.200
add address-pool=dhcp disabled=no interface=bridge1 name=dhcp1
add bridge=bridge1 interface=wlan2.4
add bridge=bridge1 interface=wlan5G
add address=192.168.1.2/24 interface=bridge1 network=192.168.1.0
/ip dhcp-server lease
add address=192.168.1.3 client-id=1:78:f2:9e:90:86:da mac-address=\
78:F2:9E:90:86:DA server=dhcp1
add address=192.168.1.7 mac-address=60:01:94:D8:E3:F5 server=dhcp1
add address=192.168.1.9 client-id=1:48:0:33:ae:66:37 mac-address=\
48:00:33:AE:66:37 server=dhcp1
add address=192.168.1.251 mac-address=40:9F:38:D0:C5:0D server=dhcp1
add address=192.168.1.252 mac-address=40:9F:38:D0:F3:CC server=dhcp1
add address=192.168.1.250 mac-address=40:9F:38:D0:FA:E6 server=dhcp1
add address=192.168.1.253 mac-address=40:9F:38:D0:D6:C7 server=dhcp1
add address=192.168.1.254 mac-address=40:9F:38:D1:07:06 server=dhcp1
add address=192.168.1.6 mac-address=24:0A:C4:10:5A:EC server=dhcp1
add address=192.168.1.8 mac-address=84:F3:EB:2A:7B:24 server=dhcp1
add address=192.168.1.15 mac-address=70:EE:50:1F:05:0C server=dhcp1
add address=192.168.1.5 client-id=1:78:24:af:41:bc:3d mac-address=\
78:24:AF:41:BC:3D server=dhcp1
add address=192.168.1.0/24 dns-server=8.8.8.8 gateway=192.168.1.2 netmask=24
set servers=8.8.8.8
add action=fasttrack-connection chain=input connection-state=\
established,related connection-type=""
add action=fasttrack-connection chain=forward connection-state=\
established,related
add action=drop chain=input
add action=dst-nat chain=dstnat dst-port=443 in-interface-list=WAN log-prefix=\
"[443]" protocol=tcp to-addresses=192.168.1.3 to-ports=443
add action=dst-nat chain=dstnat dst-port=6881 in-interface-list=WAN log-prefix=\
"[443]" protocol=tcp to-addresses=192.168.1.5 to-ports=6881
"[443]" protocol=udp to-addresses=192.168.1.5 to-ports=6881
/ip service
set telnet address=192.168.1.0/24
set ftp address=192.168.1.0/24
set www address=192.168.1.0/24
set ssh address=192.168.1.0/24
set api address=192.168.1.0/24
set winbox address=192.168.1.0/24
set api-ssl address=192.168.1.0/24
/system clock
set time-zone-name=Europe/Rome
