Hi all,
I have some problems for running OpenFlow on my routerboard - RB450G, RouterOS 6.13
I connected my Desktop to the master port as a controller and some single board PCs to slave ports as hosts, and configured them like this:
openflow add name=ofswitch controller=192.168.88.xxx // Controller (Desktop) IP address
openflow port add switch=ofswitch interface=ether3-slave-local
openflow port add switch=ofswitch interface=ether4-slave-local
After enabling all of them, I received a connection message from the POX controller on my Desktop, however, when I tested a simple firewall to block ping from one host to another, the application didn’t work.
(The app has no problem. It worked well in the mininet.)
I also tested without using master ports: controller(Desktop) to slave 3, hosts(single boards) to slave 4 and 5, however the result was same.
I did not change other things except the openflow package - Is there anything to change to make OpenFlow work?
I want to know how you run the OpenFlow in the routerboard . . .
thanks.
