Opening UDP ports for RDP Shortpath
Hi folks, hope this post finds you well!
I’m trying to set up RDP Shortpath to improve my connection to my work remote machine. To do so, I need to open some ports:
However, I can’t understand how to set up those via WinBox.
I’m using MikroTik Cloud’s DDNS solution to get my public IP, and added the DDNS name as an address list. (Although I don’t think its needed since I can filter my NAT rules as out-interface-list=WAN and it would be the same thing, right?)
/ip cloud set ddns-enabled=yes
/ip cloud force-update
/ip firewall address-list add address=dnsname.example list=public-domain comment="my public ip via mikrotik ddns"
My question is how can I set dst-nat to match those port/ip/protocol requirements, I initially tried creating a dst-nat with dst-address-list of my public-domain list, with to-addresses of the specified ip and 3478:
add action=dst-nat chain=dstnat comment="port forwarding for STUN" dst-address-list=public-domain protocol=udp to-addresses=20.202.0.0/16 to-ports=3478
But it doesn’t work, is it because the required destination address/port should be filled in the src-address src-port instead? In that case it wouldn’t work as well as I need to specify to-ports or to-addresses, right?
Furthermore, for the 443 TCP rule, if do the same way as I did above, it would break my internet connection as every HTTPS request coming through my IP will be redirected to that fixed ip.
So, how should I setup this? Am I mistaken and should be using something else instead of dst-nat?
